Boat House
Bow mount troller install
<blockquote data-quote="Gamefisher" data-source="post: 22259" data-attributes="member: 78"><p>I finished up version 1 of this project. I say version 1, because I may add reinforcements. I attached 4 2x4 blocks to the to the inside of the hull, then a 2x4 across the rear set of blocks. The plywood is attached to the crossbar, and the two forward blocks. I will seal and carpet it after I'm sure it is strong enough.</p><p></p><p>Matt</p></blockquote><p></p>
[QUOTE="Gamefisher, post: 22259, member: 78"] I finished up version 1 of this project. I say version 1, because I may add reinforcements. I attached 4 2x4 blocks to the to the inside of the hull, then a 2x4 across the rear set of blocks. The plywood is attached to the crossbar, and the two forward blocks. I will seal and carpet it after I'm sure it is strong enough. Matt [/QUOTE]
Boat House
