Trailers
Bunks - what material?
<blockquote data-quote="lighting" data-source="post: 127176" data-attributes="member: 2700"><p>Just found this site and it has a lot of good info . I have a 16 polar kraft and it is used in salt water only . It started leaking and after removing the boat off the trailer i found that it had some small pin holes where it sat on the bunk boards.Long story short treated wood and torn carpet . My question is with the Ultimate Bunk Boards can they be used with a riveted jon boat if not i am going to replace the treated boards with untreated boards . With carpet or with out carpet?</p></blockquote><p></p>
[QUOTE="lighting, post: 127176, member: 2700"] Just found this site and it has a lot of good info . I have a 16 polar kraft and it is used in salt water only . It started leaking and after removing the boat off the trailer i found that it had some small pin holes where it sat on the bunk boards.Long story short treated wood and torn carpet . My question is with the Ultimate Bunk Boards can they be used with a riveted jon boat if not i am going to replace the treated boards with untreated boards . With carpet or with out carpet? [/QUOTE]
Trailers
