FishingCop
So, my cousin (inactive member Legbrkr) was smoking an 8 lb brisket today (they smoke ribs, etc. on a Weber charcoal grill regularly.) They put the coals and wood on one half, place the meat on the other half with a pan with water underneath. It has a lift up half grate so they can add charcoal and wood as needed without lifting the whole grate up.
So... After I saw this, I was trying to figure out if I can smoke on a gas grill?
Any thoughts, suggestions? Anyone do it on a gas grill? If so, directions please.
I have a Weber 3-burner grill. Burners are left to right, not front to back. Two grates, left and right. So, if I want to keep the heat in the left side and the meat on the right side, I could put a cookie sheet type pan right down on the burner for the charcoal and wood and take off the grate. Put a pan of water down on the burner on the left and the meat on the grate top. Fire up the charcoal and wood on the left side on top of the cookie sheet and not use the gas burners.
Ha, am I dreaming? Will this work? Any help here is appreciated. Of course, I could just go by a smoker or a Weber grill - but I don't figure I'll smoke anything more than once or twice a year???
Somebody here must know how to do this - or not????
Thanks.
Thanks.
