Boat House
Carpet Removal / Install?
<blockquote data-quote="ben2go" data-source="post: 98125" data-attributes="member: 751"><p>Get all the old carpet off.Use a wire wheel on a drill to remove the rest and the old glue.Replace any wood with exterior grade not pressure treated.Pressure treated causes corrosion.I use 3M spray glue.It comes in a red and black can like spray paint.It's easier to remove later.You can stretch your carpet and wrap it around and staple it under the wood,this is a common method for installing carpet.</p><p></p><p></p><p>Try this thread for posting pics. https://www.tinboats.net/forum/viewtopic.php?f=31&t=8439</p></blockquote><p></p>
[QUOTE="ben2go, post: 98125, member: 751"] Get all the old carpet off.Use a wire wheel on a drill to remove the rest and the old glue.Replace any wood with exterior grade not pressure treated.Pressure treated causes corrosion.I use 3M spray glue.It comes in a red and black can like spray paint.It's easier to remove later.You can stretch your carpet and wrap it around and staple it under the wood,this is a common method for installing carpet. Try this thread for posting pics. https://www.tinboats.net/forum/viewtopic.php?f=31&t=8439 [/QUOTE]
Boat House
