Electrical
charging a deep cycle battery
<blockquote data-quote="bcbouy" data-source="post: 265946" data-attributes="member: 4563"><p>my charger has a setting for reinforced activation,which helps decrystalize the plates,not sure but i think its 50 amps.it also has a maintenance mode which sends a pulse to desulphate the plates if it is cold/dead or has sat for a prolonged time.ive had the same two deep cycle batts wired in series for nearly 5 yrs.i charge them both together neg on one batt. pos on the other.</p></blockquote><p></p>
[QUOTE="bcbouy, post: 265946, member: 4563"] my charger has a setting for reinforced activation,which helps decrystalize the plates,not sure but i think its 50 amps.it also has a maintenance mode which sends a pulse to desulphate the plates if it is cold/dead or has sat for a prolonged time.ive had the same two deep cycle batts wired in series for nearly 5 yrs.i charge them both together neg on one batt. pos on the other. [/QUOTE]
Electrical
