pletzy
hey folks... I'm at the wiring stage of my build. I thought I did all the research, but i'm second guessing myself. Please have a look at my diagram for wiring the poles of my contura rocker switches. I have a bunch of switches, but only put 3 on for simplicity. All are illuminated, so my biggest concern is with the ground pole for the light. There is one on/off/on for the nav lights and the rest are on/off.
First diagram is how it shows to wire the illuminated on/off switches (borrowed from the manufacturer):
Second is the illuminated on/off/on wiring diagram (again, borrowed from the manufacturer):
So here is how I interpret this (you'll have to zoom):
I think I have the on/off (A & B) ones figured out, but the on/off/on (C) i'm not 100% sure. **Also, the illumintated switches each have a ground pole for the light on the switch (7). Can I link all three grounds (7A, 7B, 7C) to the ground returning to the negative buss (5C)? If I have this entirely wrong, please let me down easy.... THANKS FOR YOUR HELP!!!
