Motors
Converging Ring
<blockquote data-quote="Bad Wolf" data-source="post: 308907" data-attributes="member: 11340"><p>The PO gave me two props, the one on the motor is black with a slight flare or bell at the trailing edge of the prop body. (not sure of the proper terms) On the other prop which I'm guessing is the Johnson prop (its the same colour as the motor) the body of the prop is straight but there is a groove at the very back which I'm assuming is where the converging ring would snap into. I would only use the Johnson prop as a spare so I don't know if its worthwhile to buy the ring.</p></blockquote><p></p>
[QUOTE="Bad Wolf, post: 308907, member: 11340"] The PO gave me two props, the one on the motor is black with a slight flare or bell at the trailing edge of the prop body. (not sure of the proper terms) On the other prop which I'm guessing is the Johnson prop (its the same colour as the motor) the body of the prop is straight but there is a groove at the very back which I'm assuming is where the converging ring would snap into. I would only use the Johnson prop as a spare so I don't know if its worthwhile to buy the ring. [/QUOTE]
Motors
Converging Ring
