DIY Nav/Homemade Pole Light
<blockquote data-quote="Dark3" data-source="post: 366447" data-attributes="member: 14036"><p>As stated its a 1" adjustable flag pole holder. 3/4 pvc tubing for the main pole, a 3/4 to 3/4 pvc connector that is stuffed into the plastic tube, a 3/4 pvc cap which is stuffed in the top of the plastic tube. Not sure what size plastic tube just fit it at home depot. 25 feet of 14 ga double wire (speaker wire). The lights from oznium 2 flush mount led bolts (no lens) one red one green. A 4.7" flexible led strip. A dpdt switch. 14 ga butt connectors, battery ring terminals and a couple twist nut connectors. A fine mist of any off whit paint on the clear tube. Conduit and thats pretty much it.</p></blockquote><p></p>
[QUOTE="Dark3, post: 366447, member: 14036"] As stated its a 1" adjustable flag pole holder. 3/4 pvc tubing for the main pole, a 3/4 to 3/4 pvc connector that is stuffed into the plastic tube, a 3/4 pvc cap which is stuffed in the top of the plastic tube. Not sure what size plastic tube just fit it at home depot. 25 feet of 14 ga double wire (speaker wire). The lights from oznium 2 flush mount led bolts (no lens) one red one green. A 4.7" flexible led strip. A dpdt switch. 14 ga butt connectors, battery ring terminals and a couple twist nut connectors. A fine mist of any off whit paint on the clear tube. Conduit and thats pretty much it. [/QUOTE]
