Boat House
Fasteners for wood floor
<blockquote data-quote="LDUBS" data-source="post: 468101" data-attributes="member: 21536"><p>I think it is very smart to think ahead for when future maintenance is going to be needed. If you liked the floating floor on your old Lowe tunnel, here is a thought. Lay the floor in and hold it down with some strategically placed aluminum angle pieces attached to where the bench sides meet the floor (or whatever vertical surface meets the floor). If this configuration would work in your boat, then it would be simple to remove the angle pieces and lift the floor out. Side benefit is you don't have to drive any kind of fastener into the ribs.</p></blockquote><p></p>
[QUOTE="LDUBS, post: 468101, member: 21536"] I think it is very smart to think ahead for when future maintenance is going to be needed. If you liked the floating floor on your old Lowe tunnel, here is a thought. Lay the floor in and hold it down with some strategically placed aluminum angle pieces attached to where the bench sides meet the floor (or whatever vertical surface meets the floor). If this configuration would work in your boat, then it would be simple to remove the angle pieces and lift the floor out. Side benefit is you don't have to drive any kind of fastener into the ribs. [/QUOTE]
Insert quotes…
Boat House
