Finally! My 14' V Restore
<blockquote data-quote="BoatingCop" data-source="post: 321141" data-attributes="member: 6164"><p>Well I've made progress and she's back in the water!! I used two 1/2" pieces of plywood, glued together with waterproof glue. I used a lot of spar urethane on it and bolted it back in. Everything was sealed up with 5200. I got a mini jacker jack plate which put the motor right where it needs to be. </p><p></p><p>I put in a bilge pump, wired up the nav lights, and hooked up a tiny tach. I cut out a piece of plywood to the size of the rear bench and carpeted it with AstroTurf from lowes. I then put in a seat base and put in a removable seat. I also mounted the tiny tach to the carpeted board. Next I want to put a floor in it for easier standing and walking. Thanks for all the help so far!![ATTACH=full]54692[/ATTACH][ATTACH=full]54693[/ATTACH][ATTACH=full]54694[/ATTACH][ATTACH=full]54695[/ATTACH]</p></blockquote><p></p>
[QUOTE="BoatingCop, post: 321141, member: 6164"] Well I've made progress and she's back in the water!! I used two 1/2" pieces of plywood, glued together with waterproof glue. I used a lot of spar urethane on it and bolted it back in. Everything was sealed up with 5200. I got a mini jacker jack plate which put the motor right where it needs to be. I put in a bilge pump, wired up the nav lights, and hooked up a tiny tach. I cut out a piece of plywood to the size of the rear bench and carpeted it with AstroTurf from lowes. I then put in a seat base and put in a removable seat. I also mounted the tiny tach to the carpeted board. Next I want to put a floor in it for easier standing and walking. Thanks for all the help so far!![ATTACH type="full" alt="ImageUploadedByTapatalk1372904767.462494.jpg"]54692._xfImport[/ATTACH][ATTACH type="full" alt="ImageUploadedByTapatalk1372904784.478661.jpg"]54693._xfImport[/ATTACH][ATTACH type="full" alt="ImageUploadedByTapatalk1372904800.044034.jpg"]54694._xfImport[/ATTACH][ATTACH type="full" alt="ImageUploadedByTapatalk1372904818.176679.jpg"]54695._xfImport[/ATTACH] [/QUOTE]
