first boat 17ft Lowe roughneck
<blockquote data-quote="JL8Jeff" data-source="post: 368462" data-attributes="member: 12995"><p>I have a 1652 Roughneck tunnel with a Merc 60/45 jet and with the center console in the middle of the boat, there is too much weight in the back and I had to add transom wedges and put 40-50 lbs up front to keep it from porpoising. I might try moving the conosle forward over the winter if I can find longer cables cheap enough.</p></blockquote><p></p>
[QUOTE="JL8Jeff, post: 368462, member: 12995"] I have a 1652 Roughneck tunnel with a Merc 60/45 jet and with the center console in the middle of the boat, there is too much weight in the back and I had to add transom wedges and put 40-50 lbs up front to keep it from porpoising. I might try moving the conosle forward over the winter if I can find longer cables cheap enough. [/QUOTE]
Insert quotes…
