Boat House
Floor material?
<blockquote data-quote="onthewater102" data-source="post: 366598" data-attributes="member: 13702"><p>Trying to figure out what you're trying to accomplish here? Are you concerned that the top layer of foam will not provide enough support to prevent you from getting depressions in the rigid foam as you walk around on it over time? If so then your corrugated plastic will probably work.</p><p></p><p>Test it on the ground - throw a sheet of rigid foam down with the plastic over it and your soft foam on top & see if it holds up - if not I'm sure the FRP will work for you. My deck is FRP with expanded foam behind it - no soft layer on top.</p></blockquote><p></p>
[QUOTE="onthewater102, post: 366598, member: 13702"] Trying to figure out what you're trying to accomplish here? Are you concerned that the top layer of foam will not provide enough support to prevent you from getting depressions in the rigid foam as you walk around on it over time? If so then your corrugated plastic will probably work. Test it on the ground - throw a sheet of rigid foam down with the plastic over it and your soft foam on top & see if it holds up - if not I'm sure the FRP will work for you. My deck is FRP with expanded foam behind it - no soft layer on top. [/QUOTE]
Boat House
Floor material?
