Getting rid of floor rattle/vibration - help please
indoman
A number of the factory rivets have either loosened or had the heads pop off so the floor in my semi-v vibrates/rattles obnoxiously at certain speeds. Other than drilling pilot holes then screwing in some stainless sheet metal screws w/finish washers into the ribs, does anyone have a idea on how to fix this issue?
Thanks
I've drilled out one of the rivets and put the screw/washer in.
Excuse the dumb question but.... don't I need to be able to buck the rivet on the bottom side? Not sure how I'd get at that side since it's inside the rib. ??
[url=https://www.tinboats.net/forum/viewtopic.php?p=327335#p327335 said:
indoman » Today, 18:15[/url]"]I've drilled out one of the rivets and put the screw/washer in.
Can't see your size from here but pop rivets are available in many sizes. I think my little kit only does up to 3/16" but bigger ones are an option. You insert the rivet into the hole and pump the handle. Out pops what look like a headless nail (trash).
You want pictures?
I figured the screws would be less likely to loosen. I didn't think of the obvious - i.e. just putting in another rivet.
I have access to a pop rivet gun and may try that if the screws don't work.
Thanks.
a rivet will be much stronger than a screw in sheet metal like that. rivets are cheaper than SS screw and washers also.
if you've already got the gun, just pick up a pack of all aluminum rivets for a 1.79 at lowes.
Drill out the rivet and replace with a larger one if necessary. A sheet metal screw will eventually loosen up or strip out over time.
Most factory boats use 3/16 rivets, and that's generally the maximum rivet size for a rivet gun you buy at Lowes or Home Depot. You can buy a rivet gun that will do 1/4" rivets at harbor Freight Tools for about 20 dollars. I bought one, and I've been slowly but surely changing out all the rivets in the floor of my jetboat to 1/4"
