Motors
HELP! Evinrude 9.9 not shifting correctly
<blockquote data-quote="bassin4fun" data-source="post: 248765" data-attributes="member: 8075"><p>Also, before installing, pull shift rod IN LOWER UNIT all the way up. this will give you a little more room to work while attaching lower unit. Keep shifter on motor in forword but, actually gearcase will be in 'reverse' . As lower unit draws up,shifter should index. Others out there.....correct me if I am wrong????</p></blockquote><p></p>
[QUOTE="bassin4fun, post: 248765, member: 8075"] Also, before installing, pull shift rod IN LOWER UNIT all the way up. this will give you a little more room to work while attaching lower unit. Keep shifter on motor in forword but, actually gearcase will be in 'reverse' . As lower unit draws up,shifter should index. Others out there.....correct me if I am wrong???? [/QUOTE]
Motors
