- Joined
- Oct 14, 2016
- Messages
- 99
- Reaction score
- 69
I have a Tracker Grizzly 1448 on the front I have a Minn Kota Ulterra 80 pound thrust on the back I have two Traxxis 80 pound thrust. Minn Kota refuses to give any estimate on how long the run time is for their motors. I know that wind weight and current will change the distance and speed achieved but it should not effect the actual run time. They give the amp usage at top speed but none for the lower speeds. The battery meters built in are like a poorly designed gas tank that will read full until it's about out of gas. I have run the two transom motors for 2 hours at 50% and still the meter shows full charge. The Ulterra read full charge for about 2 hours hard running ( I was not timing it) until it dropped to 75% then rapidly dropped to 50% then 25% in less then 30 minutes. (I had to paddle the last 200 yards) Each motor is hooked up to 120 amp hour AGM batteries. My question: How can I accurately measure the amount of discharge and calculate the remaining run time.
Information: the 2 Traxxis 80 pound thrust at max gives me 4.7MPH (speed given on the Ulterra hand device and agreeing with the Humming bird fish finder.) I like the 3 motors because I do not like rowing or paddling since the Grizzly is not designed to be rowed or paddled. If a motor fails when i am 3 or 4 miles from the ramp having the multiple motors is necessity.
