Motors
Help on my motor height
<blockquote data-quote="nccatfisher" data-source="post: 463632" data-attributes="member: 10811"><p>There is no set height exactly, it will depend on boat, weight, distribution etc. </p><p></p><p>Just set it where it performs the best and you motor still pumps a full stream of water. Make sure you do not starve your motor for water. I am lucky with T&T as I can drop mine down for starting off yet lift it up for normal running. And really jack it up in shallow water for just easing around but I do have to make sure I am still pumping water when I do that.</p></blockquote><p></p>
[QUOTE="nccatfisher, post: 463632, member: 10811"] There is no set height exactly, it will depend on boat, weight, distribution etc. Just set it where it performs the best and you motor still pumps a full stream of water. Make sure you do not starve your motor for water. I am lucky with T&T as I can drop mine down for starting off yet lift it up for normal running. And really jack it up in shallow water for just easing around but I do have to make sure I am still pumping water when I do that. [/QUOTE]
Insert quotes…
Motors
