LarryA
I'm having so problems with mainly loading my boat on the trailer. Unloading isn't too bad but could be better.
After unloading, yesterday, I looked at the bunks and they are not all that bad. There is a little wear on the carpet/padding but not worn through. The rollers are old and have some cracks and need replacing. The problem I have is that the boat just doesn't want to move. When I'm loading it is like the winch is dragging a car and the Bow is always too high. The winch tries to pull the bow down to the stop and ends up bending the bracket the Y Stop is mounted on. I've tried backing in to different depths with the trailer but that doesn't seem to make and real difference. I'm thinking that the rollers don't have enough support or the bunks are taking too much of the weight. There is currently one roller at the rear, one about 2/3 forward, and two bunks around 4 to 5 feet long. I'm wondering if the rollers are just collapsing under the weight and then the bunks are just creating too much friction. At any rate, I have no idea how to determine where the bunks should be set so they support but not try to hold all the weight.
Hope this makes sense. I was going to post a few pictures but my camera batteries are dead.
