bikerider
- Joined
- Apr 18, 2018
- Messages
- 236
- Reaction score
- 7
My boat was made in the mid 90s, so I would not be surprised if the original transom wood is pressure treated. I'm doing research now, hopefully to be completely prepared and make the transom replacement easier. What do you think worst case scenario would be once I remove the old transom wood?Sand it clean around the hole, then use JB Weld to fill the hole and feather it out around the edges.
That hole looks like corrosion, I'd want to get a better look at the inside of that transom to see how bad its corroded. Now is the time to stop it before its too far gone.
3M 5200 urethane sealer will seal that up too but its hard to get off for a more permanent repair later.
Be ready to deal with more of that sort of corrosion when you replace the transom wood.
Usually we see that on Lowe and OMC built boats of the late 80's and 90's due to the use of pressure treated wood in their transoms. Grumman, Sea Nymph, Lowe, and a few others were notorious for galvanic corrosion due to the copper content in the pressure treated wood then.
Given it is all coming apart at the end of the season, just a dab of 4200 and an SS screw similar to one in the picture will prevent any more water intrusion. If it is above the waterline, just the 4200 will do on such a small hole. When you dis-assemble at the end of the season, will need to evaluate if it is corrosion and how ad the inside surface is.
What do you think worst case scenario would be once the the transom wood is removed?Given it is all coming apart at the end of the season, just a dab of 4200 and an SS screw similar to one in the picture will prevent any more water intrusion. If it is above the waterline, just the 4200 will do on such a small hole. When you dis-assemble at the end of the season, will need to evaluate if it is corrosion and how ad the inside surface is.
Depending on mfgr and quality of boat you have, there may not be any wood in the transom. My '92 Sylvan has an all aluminum transom. Smaller boats that use clampon motors often still have wood to give a better clamping surface.My boat was made in the mid 90s, so I would not be surprised if the original transom wood is pressure treated. I'm doing research now, hopefully to be completely prepared and make the transom replacement easier. What do you think worst case scenario would be once I remove the old transom wood?
I'm currently restoring my 1979 Lowe Lake Jon 1436. When I removed the old transom wood, I couldn't believe the galvanic corrosion that was there. The transom aluminum was full of holes and paper thin. I bought some 1/16" aluminum sheets and closed end aluminum pop rivets that I am going to sandwich the transom with. I also bought a piece of 3/4" white oak plywood for the transom replacement.Sand it clean around the hole, then use JB Weld to fill the hole and feather it out around the edges.
Yeah, true. I'll have to see how bad it is once the old wood's removed.I don't see much use in speculating vs examining at the end of the season. Worse case is that there is allot of corrosion and it would need to be re-skinned. If you only have the one hole, think that is highly unlikely, though. The hole might not be corrosion or there is minimal corrosion that can be cleaned up and resealed.
Interesting. I believe I saw a replacement aluminum transom for sale over on tiny boat nation.Depending on mfgr and quality of boat you have, there may not be any wood in the transom. My '92 Sylvan has an all aluminum transom. Smaller boats that use clampon motors often still have wood to give a better clamping surface.
That's a bummer. Are you worried about the structural integrity of the original aluminum, even after adding new aluminum around the new transom wood? I've seen several others talking about using white oak as their new transom wood. What are you planning to seal it with?I'm currently restoring my 1979 Lowe Lake Jon 1436. When I removed the old transom wood, I couldn't believe the galvanic corrosion that was there. The transom aluminum was full of holes and paper thin. I bought some 1/16" aluminum sheets and closed end aluminum pop rivets that I am going to sandwich the transom with. I also bought a piece of 3/4" white oak plywood for the transom replacement.
At least on most jon boats the transom wood doesn't cover the full transom, so structure wise its rarely an issue.I'm currently restoring my 1979 Lowe Lake Jon 1436. When I removed the old transom wood, I couldn't believe the galvanic corrosion that was there. The transom aluminum was full of holes and paper thin. I bought some 1/16" aluminum sheets and closed end aluminum pop rivets that I am going to sandwich the transom with. I also bought a piece of 3/4" white oak plywood for the transom replacement.
