perchin
Hey guys, I thought I would post this, in order to help out some of the guys with fears of doing rivets. This is a very easy process. If.....you own a air compressor that is.
To start out you have just drilled out lets say your seat and now have many holes in your hull. You have ordered solid aluminum rivets from your source, (here is mine)
https://www.mcmaster.com/ and are ready to install them. I bought a air hammer from lowe's for only like $20.00, and a rivet bit for $7.00. I also have a chunk of steel, which you will need.
Air hammer with the rivet bit in.
chunk of steel, this one is one of those body work backers.
These are 1/4" diameter rivets, so use a 1/4" drill.= nice snug fit.
Drill out your hole to the proper size.
After drilling out your hole, use the chunk of steel to de-bur around the hole.
Now insert the rivet, (sometimes it needs some small taps of the hammer)and firmly press the chunk of steel against the head of the rivet.
With the other hand use the air hammer on the Rivet, only zap it a few quick pulls of the trigger, (unless you are using short rivets, I ordered all 1/2" to be safe.) This will do the initial seating of the rivet.
I then, becuase the rivet is too long, grind it off a little bit.
Now place the steel back on the rivet head, and use the air hammer to finish off the rivet. You will need to do short bursts on the gun and do kinda a circular motion and angle the gun around a bit in order to achieve a nice rounded off finish. And wala!!!
