Hubbs' 1989 MonArk Legend 170 Mod V Project
Hubbs
NE Texas
Hey fellas,
I've been lurking here for the past year or so while I worked on a project that has now reached completion (if that's possible with a boat :lol: )
Thought I would post some of the details and pictures of my build
The boat is a '89 MonArk 17' all welded aluminum hull jon-style bass boat. Nothing fancy but enough room and features to make a day on the lake enjoyable. Both the boat and trailer were in rough shape. After a thorough inspection I decided it was worth the $600 asking price. The outboard was not included.
First order of business was a float test to check stability and for leaks.
With the boat floating I was able to give the trailer a closer inspection. No major problems.
Welcome aboard. Great looking boat. I look forward to seeing the project.
After suspending the boat from the carport rafters, I was able to roll the trailer out.
I went to work breaking the trailer down and attacking the surface rust. Along with a fresh coat of primer and paint I ended up replacing the wheels, tires, leaf springs, winch, coupler, safety chains, lights, bunks, and rollers.
Yep, basically everything.
The axle and the hubs were in good condition. I replaced the bearings, races, and bearing buddies. Repacked with new grease of course
Trailer before:
After:
I scoured craigslist daily looking for deals on the parts that I was going to need to finish the boat.
I came across a MinnKota 54# bow mounted, foot controlled trolling motor for $200.00 Its a Maxxum series 24v.
Once the trailer was finished, I began tearing out the boat. I took it down to the metal including all decks, flooring and foam. The foam was saturated with water and was obstructing the passages that water needed to flow to the bilge.
Nice boat. You should post some pictures of the trailer in trailer forum.
Thanks, I'll be sure to do that.
While gutting the boat I started researching some options for putting it back together.
Decided that I wanted to use the boat for fishing and duck hunting. And since I can fish year round in Texas I figured that will be the main purpose and duck hunting would be second.
Next I focused on stripping the old decals and prepping the surface to receive paint.
Laid down 2 coats of self-etching primer. It chemically binds to the bare aluminum and because its OD green it also serves as the base layer for the camo pattern.
It was about this time that I came across the big motor for my boat on craigslist
Its an 1977 Evinrude 70hp and I gave $500 for it.
I went ahead and prepped it with the same etching primer that I used on the boat
Inspired by several projects that I saw on this forum, I wanted a professional looking camo pattern.
Decided to use a stencil kit and take my time to get it right.
Picked up some yard sale signs in both large and small formats
Made some leaf stencils first
Taped a few leaves and sprayed for an outline
Cut out the leaf and sprayed a test run on a piece of scrap wood. Worked well if I do say so myself.
Larger signs for the main camo pattern
The trick to doing a good camo pattern is to work in layers.
The base layer is the self-etching primer. On top of this I randomly placed sweeping arcs with flat white.
Then using a stencil I applied a layer of brown. It appears much more orange in this picture than it actually is.
Next comes a layer of black shot thru a stencil with many narrow slits.
Here's what it looks like with 4 layers done.
A look at the entire boat done with 4 layers. BTW the adapter that clips onto the spray cans is a life saver.
Now to use the grass stencil I made
Boat going back onto the trailer.
Hung the motor and camo'd it to match the boat
Picked up a Lowe side console and windshield off ebay.
Some seats from Academy sports. Testing the layout.
Built a bench for the seats and added storage
Installed the livewell pump
Installed gauges and switches.
Wired up the lighted rocker switches for nav lights, bilge pump, and livewells. All switches are independent of the key switch. Still leaves 2 switches unassigned. I'm thinking of installing some LED courtesy lights later which will take a switch and I will probably use the last switch for a 12V accessory outlet.
Wired the gauges. Backlights run off of the key switch. Tach runs off of the Evinrude, volts from cranking battery, and fuel from the sender in the tank. The speedo works off of a pitot attached to the transom.
I still need to install an ignition interrupter switch (a.k.a kill switch) for safe boating. Its not a requirement but I think its a good idea to have one.
Also installed the steering wheel I picked up from ebay.
I went back and forth trying to decide how to cover the decks and floor.
I would have preferred to of used sheet aluminum coated with a bedliner material. For the sake of expense I elected for an alternative
What I finally settled on was 5/8 exterior grade plywood treated with Thompson's WaterSeal.
I thought that a porch and floor paint with polyurethane would work well. I coated both sides of all plywood but it still didn't look quite the way I wanted.
I turned to carpet for the solution.
Found so decent quality marine carpet at the local home store. I used contact cement and stainless staples to install it.
I paid attention to the details and took my time. Kept the "grain" of the carpet running in the same direction.
Under the rear casting deck is the fuel tank, 2 Interstate 27 series deep cycle batteries, 1 cranking battery and the on board 3 bank battery charger. There is also room for an extra prop, small took kit and some 2 stroke oil.
Carpet looks great. Good job. If you don't mind me asking, how much did it run you? How many square feet? I am looking to get carpet for my boat this weekend. I have looked at Bass Pros and Cabelas. Might be cheaper to go with the Home Depots or Lowes option.
