Motors
Impeller on 5hp Gamefisher (Formerly... Arrrrrggggghhhhh)
<blockquote data-quote="ben2go" data-source="post: 86241" data-attributes="member: 751"><p>put the lower unit in gear and try wiggling the prop back and forth while seating the shaft.The tolerances are fairly tight that is why it's so hard to line up.Also try a little lube on the splines.WD40 or something.</p></blockquote><p></p>
[QUOTE="ben2go, post: 86241, member: 751"] put the lower unit in gear and try wiggling the prop back and forth while seating the shaft.The tolerances are fairly tight that is why it's so hard to line up.Also try a little lube on the splines.WD40 or something. [/QUOTE]
Motors
