Jet Boats
General Jet Boat Discussions
Jet outboard troubleshooting
<blockquote data-quote="handyandy" data-source="post: 458915" data-attributes="member: 18942"><p>That should help it, knowing how to remove, sharpen, and shim your own impeller is imperative if your going to continue owning/running an obj. If you search on here there are a couple of older threads that have pictures and descriptions of how to sharpen. lil blue rude prefers to sharpen what would be the top of the leading edges of the impeller vs the bottom as obj recommends on their site. I prefer this method as well the leading edges the ones that are picking up water so the ones on the bottom when the impeller is installed sharpen the the top of them.</p></blockquote><p></p>
[QUOTE="handyandy, post: 458915, member: 18942"] That should help it, knowing how to remove, sharpen, and shim your own impeller is imperative if your going to continue owning/running an obj. If you search on here there are a couple of older threads that have pictures and descriptions of how to sharpen. lil blue rude prefers to sharpen what would be the top of the leading edges of the impeller vs the bottom as obj recommends on their site. I prefer this method as well the leading edges the ones that are picking up water so the ones on the bottom when the impeller is installed sharpen the the top of them. [/QUOTE]
Jet Boats
