Motors
Johnson 48 SPL Reverse "Lock"
<blockquote data-quote="silentbravo" data-source="post: 483676" data-attributes="member: 29669"><p>The cable goes from that lever into the side of the tilt assist ram, there is a fitting on the side of the ram. Mine seems to "do something" but it doesn't lock the motor, I can still lift it with the lever in either position. Going to keep investigating this....</p><p></p><p>I did lift the motor and set it on the kickstand to keep it up while I inspected, then let it down with reverse lock lever in the lock position. The motor went about 80% of the way back down, but it seemed to keep some fluid locked in the ram and motor was not quite all the way back down to resting state. I set the lock lever back and it released some pressure and went all the way back down.</p></blockquote><p></p>
[QUOTE="silentbravo, post: 483676, member: 29669"] The cable goes from that lever into the side of the tilt assist ram, there is a fitting on the side of the ram. Mine seems to "do something" but it doesn't lock the motor, I can still lift it with the lever in either position. Going to keep investigating this.... I did lift the motor and set it on the kickstand to keep it up while I inspected, then let it down with reverse lock lever in the lock position. The motor went about 80% of the way back down, but it seemed to keep some fluid locked in the ram and motor was not quite all the way back down to resting state. I set the lock lever back and it released some pressure and went all the way back down. [/QUOTE]
Insert quotes…
Motors
