Motors
Johnson/seahorse 87's Carb needle adjustment
<blockquote data-quote="airshot" data-source="post: 497240" data-attributes="member: 1183"><p>I always start at 1 1/2 turns out and go from there, with that said, did you clean out that passage for that needle really well ?? Slightest spec of dirt can change everything !</p><p>Check the end of the needle carefully, I have saw where the end was damaged from over tightening and that can cause issues also.....just some food for thought...</p></blockquote><p></p>
[QUOTE="airshot, post: 497240, member: 1183"] I always start at 1 1/2 turns out and go from there, with that said, did you clean out that passage for that needle really well ?? Slightest spec of dirt can change everything ! Check the end of the needle carefully, I have saw where the end was damaged from over tightening and that can cause issues also.....just some food for thought... [/QUOTE]
Motors
