Off The Water
Watering Hole
Just made a short fishing video with my new GoPro Hero 3
<blockquote data-quote="DocWatson" data-source="post: 288387" data-attributes="member: 112"><p>I assume that you are adding the music tracks to your videos as part of the edit for show process. Unless I'm wrong, the copyright enforcement online is based on the music title as part of the content. If that's the case, you could probably just change the title of the track before inserting it into the edit. </p><p></p><p>Perhaps creating a folder for the music before you start the edit then adding copies of the tracks in the order you want them to the folder changing the titles to Track1, Track2, etc. might make this process a bit less of a PITA to do. Unfortunately, I'm not sure it will help with already created videos.</p><p></p><p>This is all speculation based on how the copyright might be enforced, but it may be worth a shot with one video to try it.</p></blockquote><p></p>
[QUOTE="DocWatson, post: 288387, member: 112"] I assume that you are adding the music tracks to your videos as part of the edit for show process. Unless I'm wrong, the copyright enforcement online is based on the music title as part of the content. If that's the case, you could probably just change the title of the track before inserting it into the edit. Perhaps creating a folder for the music before you start the edit then adding copies of the tracks in the order you want them to the folder changing the titles to Track1, Track2, etc. might make this process a bit less of a PITA to do. Unfortunately, I'm not sure it will help with already created videos. This is all speculation based on how the copyright might be enforced, but it may be worth a shot with one video to try it. [/QUOTE]
Off The Water
Watering Hole
