First post, and I want to thank you guys for all the great info on this Forum!
Picked up a Lund Laker, and the Trailer lights were a mess.
Bought a new harness, and a set of LED markers and tail lights to install.
The Tail lights work perfectly, but the side markers are not working at all. Initially, I had grounded the markers to the posts. During trouble shooting I decided to drill a small bolt into the frame for the ground (after seeing how the tail lights would not work at all without a tight ground connection) I also switched the wiring on the quick connect to make sure that I didn't have the wiring hooked up backwards, and nothing. I cant even get them to flicker in any setting
The tail lights are grounded to the mounting posts, and the harness is grounded to a bolt on the tongue. I have solid wires running to the tail lights, and quick connect splices for the markers.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
