cavman138
Anyone have use a livewell timer? If so, what do you recommend?
The last system I put in a boat said several time do not leave the pump running all the time as it will kill the fish. I think it has more to do with what kind of pump it is. If your just recircing the water then that is probably fine. But this was a fresh water pump with a huge overflow and it said leaving the pump on all the time will drown the fish. Apparently there is too much flow for them to be able to breathe properly. That is why that system came with a timer so that it would cycle when it was on and off.redbug said:when it comes to fish care you are much better off leaving the live well run ful time..
huntinfool said:The last system I put in a boat said several time do not leave the pump running all the time as it will kill the fish. I think it has more to do with what kind of pump it is. If your just recircing the water then that is probably fine. But this was a fresh water pump with a huge overflow and it said leaving the pump on all the time will drown the fish. Apparently there is too much flow for them to be able to breathe properly. That is why that system came with a timer so that it would cycle when it was on and off.redbug said:when it comes to fish care you are much better off leaving the live well run ful time..
Russ, have you checked to see if the timer has a setting on it. Some of the timers you whould be able to set so that it will run for 1 minute and off for 5 or something like that. Might just check into that.Like this https://www.basspro.com/webapp/wcs/...225000000_225003000?cmCat=CROSSSELL_THUMBNAIL
