Boat House
Long shaft, short transom
<blockquote data-quote="RaisedByWolves" data-source="post: 442530" data-attributes="member: 22989"><p>Im redoing my rotted transom and I bought oak plywood to raise the transom to fit my $50 CL longshaft 25hp evenrude. The transom is 20" but the engine is 22" which Im not sure if thats normal or what.</p><p></p><p>I plan on sandwiching two identical pieces of ply into a truncated pyramid shape which I figure will be stronger than if I used a 2" spacer on top of the new transom. The two plys will be glued and sealed with polyester resin.</p><p></p><p>Later if I go with a different engine with a shorter shaft length I can easily cut it down to meet whatever needs.</p></blockquote><p></p>
[QUOTE="RaisedByWolves, post: 442530, member: 22989"] Im redoing my rotted transom and I bought oak plywood to raise the transom to fit my $50 CL longshaft 25hp evenrude. The transom is 20" but the engine is 22" which Im not sure if thats normal or what. I plan on sandwiching two identical pieces of ply into a truncated pyramid shape which I figure will be stronger than if I used a 2" spacer on top of the new transom. The two plys will be glued and sealed with polyester resin. Later if I go with a different engine with a shorter shaft length I can easily cut it down to meet whatever needs. [/QUOTE]
Boat House
