I have been in the market for a cheaper flat bottom jon boat for a while now. It will get used maybe a few hours about 12 weekends a year. I have found two and debating on which would be the better option if any. Both are riveted boats and same 16ft overall design.
Bass Tracker: 1984, no leaks an overall decent shape for age. Has 25hp johnson that runs but does sounds like it is sucking air from somewhere. I havent looked too much at it yet want to do compression test first.
Lowe: 1979 carpet was just redone and needs a couple little things to finish hooking up trolling motor. It comes with a 40hp Tohatsu. I am supposed to look at this weekend but from pics it has a long shaft motor an anti-caviation plate looks to be about 5 inches below bottom of boat so think it should have short shaft on it.
Neither boat has any leaks but the bass tracker is 1200 where the lowe is 1800, both have been for sale a while so they may come down some on asking price. Is it worth the extra 600 to go with the lowe with bigger motor or save the money? Anything I should loo out for on either of these boats besides the rivets and leaking?
