Boat House
Lund Front Deck Support Help
<blockquote data-quote="kevin t" data-source="post: 384392" data-attributes="member: 17753"><p>Looked at it tonite and am going to take the whole deck off and use alum brackets tied in to cross bracing with pre-determined spacing setup for trolling motor bracket. Should not need more than 3 cross braces. Stainless lags into plywood should work...may also backplate the bottom with diamond plate for added overall strength. I may also leave the cross brace currently in and just cut it off straight, just to not mess with bow movement.</p><p></p><p>Thanks a bunch for the help.</p></blockquote><p></p>
[QUOTE="kevin t, post: 384392, member: 17753"] Looked at it tonite and am going to take the whole deck off and use alum brackets tied in to cross bracing with pre-determined spacing setup for trolling motor bracket. Should not need more than 3 cross braces. Stainless lags into plywood should work...may also backplate the bottom with diamond plate for added overall strength. I may also leave the cross brace currently in and just cut it off straight, just to not mess with bow movement. Thanks a bunch for the help. [/QUOTE]
Boat House
