Wildman
I am in the planning stages in building my console with 15 gallon live well under the front passenger seat. The live well will be Epoxy resin fiberglassed. I am building the inside floor with the bottom slopped the back wall. I have two thoughts and need opinions.
1: Put in a bilge pump with a cover for protection and at 2" put in a auto switch to turn the pump on for over flow. In other words, when the water level (if the intake is left on) gets to a level that is too close to the top the float turns on the bilge and the bilge pumps water out the over flow. When/If I hear water pumping out I know I left the intake on. The bilge will have an auto/on switch so I can manually turn it on to bilge/empty the live well.
or
2: Plumb in a manual drain in the bottom of the live well that goes to my bilge area for drainage when I empty the live well and an over flow piped that is plumed into the drain line; if I have an over flow then it goes into my bilge area.
Here is my issue. I am picking up my sole/floor 1.5". The sole will be fiberglassed so I don't think that water getting to the bottom of it will harm anything, but the purpose is not to have water in the bottom of my boat if I can help it. I don't know that there will be enough fall to keep all the water at the bilge area and my bilge pump keeps at least the ribs + full of water. In other words, if I drain/over flow manually to bilge, I will constantly have some water in the bottom of my boat. I can't over flow to a wall because the center console does not allow for a drain above water level.
If I use a float and bilge it is more "stuff that can break" but I can put in a manual plug in case I have to empty the tank.
So, what is your opinion? Manual drain/over flow or float and bilge over flow?
or
