Motors
Mercury 6hp wont stay running - oil and wh. smoke from exhau
<blockquote data-quote="earl60446" data-source="post: 390089" data-attributes="member: 4469"><p>" Tank and line don't need to be connected do they? "</p><p></p><p>Yah</p><p></p><p></p><p>" I'm now assuming that the water pump is located directly on the carb and throttle housing area? "</p><p></p><p>Probably not.</p><p></p><p>If you mean fuel pump, most are powered by pressure off the crankcase and located on side of motor, diaphram type.</p><p></p><p>Tim</p></blockquote><p></p>
[QUOTE="earl60446, post: 390089, member: 4469"] " Tank and line don't need to be connected do they? " Yah " I'm now assuming that the water pump is located directly on the carb and throttle housing area? " Probably not. If you mean fuel pump, most are powered by pressure off the crankcase and located on side of motor, diaphram type. Tim [/QUOTE]
Insert quotes…
Motors
