Musky lure storage "The Musky Bucket"
Hoffmeyer
Just though I'd post some pics of the 5 gallon bucket I modified to store my large musky lures since I can't afford an actual musky tackle box. I just used a sawzall to make the vertical cuts down to the molded "ring" in the bucket and then I drilled a small hole at the bottom of the cut so that to hook that hangs over fits down inside the ring and cannot get snagged on anything. I also drilled holes in the bottom of the bucket to all the water to drain as the baits dry.
