What was your prep routine before you started painting. I have a 14' Starcraft that is nearly identical, except that the sheet metal under the bench seats does not attach to the hull and is only attached to the wooden bench seats. These are great boats. Mine has a few leaks that have been getting worse over the past few years, so we are at the planning stage for an overhaul.
