Motors
Need lower unit for Johnson 48 SPL (1993 model)
<blockquote data-quote="thedude" data-source="post: 471404" data-attributes="member: 23372"><p>Well, good news. I located a full parts motor with low compression. paid $700 total which included new water pump, pressure check, and oil change. </p><p></p><p>I'm happy with this outcome all things considered. took it out for a lake test and everything worked smoothly!</p><p></p><p>one intriguing thing is that this "new" parts motor has a fully operational tilt assist. I really want to put this on my motor purely for the reverse lock feature (i have aftermarket CMC tilt and trim). this sounds simple enough and maybe i just need more PB blaster and a bigger hammer to unlodge the unit. getting a pressurized unit to line up to remove and replace the bolts seems near impossible. anyone with ideas would be helpful since youtube has not proved to have any great replacement video.</p></blockquote><p></p>
[QUOTE="thedude, post: 471404, member: 23372"] Well, good news. I located a full parts motor with low compression. paid $700 total which included new water pump, pressure check, and oil change. I'm happy with this outcome all things considered. took it out for a lake test and everything worked smoothly! one intriguing thing is that this "new" parts motor has a fully operational tilt assist. I really want to put this on my motor purely for the reverse lock feature (i have aftermarket CMC tilt and trim). this sounds simple enough and maybe i just need more PB blaster and a bigger hammer to unlodge the unit. getting a pressurized unit to line up to remove and replace the bolts seems near impossible. anyone with ideas would be helpful since youtube has not proved to have any great replacement video. [/QUOTE]
Motors
