Boat House
Need some flooring ideas
<blockquote data-quote="mbweimar" data-source="post: 381464" data-attributes="member: 9884"><p>VA, thanks for the reply. I just now saw it. </p><p></p><p>I'm thinking I may remove all the foam from under the floor when I replace it. That or somehow elevate the foam off the bottom of the boat, because when I rinse the boat off after being on the flats all day, there wont be anything to under there to hold water. I will replace this positive buoyancy with float pods on the transom and place foam behind the side panels of the boat.</p></blockquote><p></p>
[QUOTE="mbweimar, post: 381464, member: 9884"] VA, thanks for the reply. I just now saw it. I'm thinking I may remove all the foam from under the floor when I replace it. That or somehow elevate the foam off the bottom of the boat, because when I rinse the boat off after being on the flats all day, there wont be anything to under there to hold water. I will replace this positive buoyancy with float pods on the transom and place foam behind the side panels of the boat. [/QUOTE]
Boat House
