leadnbrass
Have a Crestliner Canadian with the factory seats.
This link is what my seats look like (hope it shows up)
https://i.ebayimg.com/00/s/MTIwMFgx...R8nW+19BS(F1iqh0!~~60_1.JPG?set_id=880000500F
The problem I am having is the padded section (white) is coming off from the bottom and seat back area (gray).
Its just a heavy stiff vinyl with foam underneath.
My idea was to pull the padding from the base and seat back...clean and scuff the areas...spray and adhesive (3m maybe) and re-bond it.
Any ideas if this should work?
I can attempt to get actual pictures of the seats if what I posted above makes no sense.
I like the seats minus this issue and they still look good just losing the backing it seems.
Comparable Attwood seats are $225 each...rather try something else first.
Thanks.
Thanks.
