neg bus placement
mrdrh99
Omaha, NE
Where do you guys have your neg bus placed? Does it need to be in direct contact to the boat or can it be inside a box o plan to make and place under the console?
Not in direct contact with the boat (the boat should NOT be used as a ground).
Putting it near the fuse panel is the easiest way, then your + and - wire runs from your accessories are about the same length.
Other than that, you can put it about anywhere.
