Hello, it has been a while since I've joined. At that time, I'd had already completed a 14' Starcraft conversion:
https://www.canadalake.org/Starcraft67.html
https://www.canadalake.org/Starcraftii.html
I have been looking on and off for another good project boat, and was focused on wide style jon boats. I finally pulled the trigger. I purchased a 1995 Discovery Marine Inc (DMI) 1648 with a 1998 Mercury 25HP Electric Start Tiller. The motor is in excellent shape, and the boat hull does not have any major damage to contend with. The bench seats were removed by previous owner, and small modifiations done. Overall, a good platform for modification.
The plan for now will be running and using for the summer. Testing for stability for decks, and how much weight I can expect to add without turning the boat into a plow. Along with, the "fun" stage of planning boat layout and construction techniques. Construction will start in the late fall when the Starcraft returns from up north.
So, this is just a warning for a number of specific posts/questions to follow. :roll: I do try to search and read what I can, but sometimes getting a fresh opinion is in order.
BTW: DMI was a small local (Preble, NY) alum boat mfg that either went under or was assimilated by a larger company. I thought it was Misty Harbor/Ultracraft, but their current line-up dosn't include the same jon boat. The boat construction looks very similiar to many other mod V jons, such as the Alumacraft 1648.
