Motors
New to me 73' Johnson 9.5
<blockquote data-quote="JRyno10" data-source="post: 376105" data-attributes="member: 8902"><p>This is only the second outboard that I have worked on, however the previous one I worked on - I replaced the same thing - the water pump. </p><p></p><p>The first time I did this it was one a 1968 6hp Evinrude.</p><p></p><p>Ok, so I just pulled the lower unit off, unscrewed the 4 screws that hold the water pump housing on, and gently began to slide the housing off the drive shaft. Well As I was doing this the drive shaft came right along with it. My gut tells me that this isn't supposed to happen - at least it did not happen when I did this on the 6hp a couple years ago. Anybody have an idea?</p></blockquote><p></p>
[QUOTE="JRyno10, post: 376105, member: 8902"] This is only the second outboard that I have worked on, however the previous one I worked on - I replaced the same thing - the water pump. The first time I did this it was one a 1968 6hp Evinrude. Ok, so I just pulled the lower unit off, unscrewed the 4 screws that hold the water pump housing on, and gently began to slide the housing off the drive shaft. Well As I was doing this the drive shaft came right along with it. My gut tells me that this isn't supposed to happen - at least it did not happen when I did this on the 6hp a couple years ago. Anybody have an idea? [/QUOTE]
Motors
