Newbe Looking for your input
<blockquote data-quote="ericman" data-source="post: 376339" data-attributes="member: 11909"><p>Be careful spraying in foam insulation. If there is no foam in the seats, take the tops off and place a board from port to starboard on the bottom of the boat (inside the seat). This will prevent foam from going all the way to the floor. You want a gap for water to flow under. In fact, I would recommend sheet foam that you can cut to shape and stack up inside the seat. This will actually be cheaper. (There is more volume of sheet foam for the price you spend)</p></blockquote><p></p>
[QUOTE="ericman, post: 376339, member: 11909"] Be careful spraying in foam insulation. If there is no foam in the seats, take the tops off and place a board from port to starboard on the bottom of the boat (inside the seat). This will prevent foam from going all the way to the floor. You want a gap for water to flow under. In fact, I would recommend sheet foam that you can cut to shape and stack up inside the seat. This will actually be cheaper. (There is more volume of sheet foam for the price you spend) [/QUOTE]
