Motors
Not Pumping a Drop of Water - 68 evinrude 6hp (6802R)
<blockquote data-quote="Pappy" data-source="post: 308053" data-attributes="member: 3278"><p>That is correct. Plenty of water should be coming out of the reliefs at the rear of the exhaust housing. </p><p>Would make sure you have a drive pin between the impeller and the driveshaft. Impeller will just spin on the shaft if it is not there.</p><p>Also make sure the pump engaged the water tube. Seriously doubt there is anything clogging the tube.</p></blockquote><p></p>
[QUOTE="Pappy, post: 308053, member: 3278"] That is correct. Plenty of water should be coming out of the reliefs at the rear of the exhaust housing. Would make sure you have a drive pin between the impeller and the driveshaft. Impeller will just spin on the shaft if it is not there. Also make sure the pump engaged the water tube. Seriously doubt there is anything clogging the tube. [/QUOTE]
Motors
