:evil: :evil:
Sure enough look at this below Here is the kicker, It's up to me to find the problem now........
Dear Customer,
In our efforts to provide you with the latest and most stable server environment we have made an important server upgrade. The server's default PHP version has been upgraded to the latest PHP 5.2 branch. This version introduces important security, performance and compatibilities improvements over the previous versions.
Before making this change we have made thorough tests to ensure this upgrade will be seamless to the end user. That's why we don't expect problems with any standard and popular PHP applications.
In vary rare cases you may experience some issues due to PHP 5.2 and we explain below how they should be solved:
1. Remote Code Inclusion issues:
If you are a developer and have made custom code, it is important to know that this version of PHP introduces a new PHP directive called "allow_url_include". This directive is set to Off by default and prevents remote code inclusion with "include" and "require" PHP functions. For issues with this directive please check this article in our Knowledge Base:
https://kb.siteground.com/article/How_to_include_remote_code_in_Php_52.html
2. Incompatibility of a script with PH P 5.2
If you have created a script or you use a ready one that is not compatible with PHP 5.2, you can easily change the PHP version for your account reading this article:
https://kb.siteground.com/article/How_to_have_different_Php__MySQL_versions.html
Known issues:
- VtigerCRM 5.0.3 does not support natively PHP 5.2. You should either switch to PHP 5 or apply the following patch:
https://wiki.vtiger.com/index.php/Vtiger_CRM_on_PHP_5.2.x
- Some OsCommerce installations may experience problems especially when the SEF functionality has been enabled. In such cases please change the PHP version to PHP 5.1.
Thank you for your support in our efforts to provide better service.
