One last Paint Prep Question
<blockquote data-quote="TexasLoneStar56" data-source="post: 369412" data-attributes="member: 14624"><p>Vinegar and water 50/50 will clean the aluminum. Rinse with clear water afterwards.</p><p></p><p>Etching primer is what is used and will fill in any small irregularities. Then base coat/clear coat. All can be found at your local paint & body supply store. Jones Blair; Sherwin Williams; PPG; DuPont.</p><p></p><p>Be sure to follow the steps and directions so that your project lasts for years to come. Prep is the key to a great paint job!</p><p></p><p>Good luck!</p></blockquote><p></p>
[QUOTE="TexasLoneStar56, post: 369412, member: 14624"] Vinegar and water 50/50 will clean the aluminum. Rinse with clear water afterwards. Etching primer is what is used and will fill in any small irregularities. Then base coat/clear coat. All can be found at your local paint & body supply store. Jones Blair; Sherwin Williams; PPG; DuPont. Be sure to follow the steps and directions so that your project lasts for years to come. Prep is the key to a great paint job! Good luck! [/QUOTE]
Insert quotes…
