Jet Boats
General Jet Boat Discussions
Pinpointing a hull leak?
<blockquote data-quote="jackpen" data-source="post: 303320" data-attributes="member: 11000"><p>Seth,</p><p></p><p>I recently had a leak in my boat that required me to run the bilge after a couple hours of fishing. I was able to find my leak by filling the boat with water. It was the pvc pipe where the aerator went through the hull. I'd cracked it on a rock sometime during the season. Since you filled your boat and found no leaks you may want to check the hose and connections between the aerator and live well. The pressure of filling a boat may not be enough to show a leak in the hose. Just a thought.</p></blockquote><p></p>
[QUOTE="jackpen, post: 303320, member: 11000"] Seth, I recently had a leak in my boat that required me to run the bilge after a couple hours of fishing. I was able to find my leak by filling the boat with water. It was the pvc pipe where the aerator went through the hull. I'd cracked it on a rock sometime during the season. Since you filled your boat and found no leaks you may want to check the hose and connections between the aerator and live well. The pressure of filling a boat may not be enough to show a leak in the hose. Just a thought. [/QUOTE]
Jet Boats
