fishbuster
I bought a 1997 Tracker Pro 17 with a 40 hp over the winter. The steering cable was seized when I bought the boat but I figured I would be able to free it up with some PB blaster. The boat had been sitting for a few years. Well after trying a couple things I am still unable to get the steering to budge. I am going to try applying some heat this weekend, but if that doesn't work it looks like I am going to have to remove the cable and tilt tube together and try separating them or replacing both.
It looks like replacement tilt tubes are too expensive so I plan on buying one and installing it as soon as I take out the old one. Based on what I could find on line it looks like I need to borrow a hoist to support the out board when I remove the tube, but it doesn't look too bad to replace.
Just wondering if any one has replaced the tilt tube on their out board before and if there is anything I should keep in mind.
Also wondering if any one has replaced the steering cable on a similar Tracker and what type they got and if there is anything to watch out for.
Thanks for the help
Joe
Thanks for the help
Joe
