Motors
Powerhead swap
<blockquote data-quote="Pappy" data-source="post: 428286" data-attributes="member: 3278"><p><span style="font-size: 18px">Another step in that process is the powerhead base gasket. Take a look at both years and see if the base gaskets match. </span></p><p><span style="font-size: 18px">You will then have ignition to contend with. Bosses on the powerhead for electronic ignition will probably NOT be on the early p'head. </span></p><p><span style="font-size: 18px">Linkage for throttle, shift, and timing may also be different. Differences in porting and carburetion. Lots for you to take a look at and I doubt you will get a one-stop shopping answer here. </span></p></blockquote><p></p>
[QUOTE="Pappy, post: 428286, member: 3278"] [size=5]Another step in that process is the powerhead base gasket. Take a look at both years and see if the base gaskets match. You will then have ignition to contend with. Bosses on the powerhead for electronic ignition will probably NOT be on the early p'head. Linkage for throttle, shift, and timing may also be different. Differences in porting and carburetion. Lots for you to take a look at and I doubt you will get a one-stop shopping answer here. [/size] [/QUOTE]
Motors
Powerhead swap
