Motors
Pressure tank question?????
<blockquote data-quote="Pappy" data-source="post: 218390" data-attributes="member: 3278"><p>Your statement is a little vague. When you do a pressure tank you need to replace the diaphragm, the gasket and the seals on each individual attachment screw. The latter can be nothing more than plastic washers purchased through a hardware store. The answer is no on the need for a sealer. When used, the sealer will often allow the gasket to migrate or slide while tightening the fasteners.</p></blockquote><p></p>
[QUOTE="Pappy, post: 218390, member: 3278"] Your statement is a little vague. When you do a pressure tank you need to replace the diaphragm, the gasket and the seals on each individual attachment screw. The latter can be nothing more than plastic washers purchased through a hardware store. The answer is no on the need for a sealer. When used, the sealer will often allow the gasket to migrate or slide while tightening the fasteners. [/QUOTE]
Motors
