Project questions!
mbarrett1379
Hello all,
I'm going to be starting on a project boat but before I start I have a few questions on your framing.
Everyone seems to be using aluminum and rivetig etc. what type of aluminum are you using and where can I get it somewhat cheap. Are you guys riveting the frame right to the boat or just setting it in the boat and using brackets to screw it in. Welding? My boat doesn't have the seats in it so basically it's an aluminum hull. Just need some pointers. Also for paint what do you guys suggest on the outside. It's a 14ft starcraft deep v.
Thanks I really appreciate any help
Here's my .02 cents. This is how I would do it if it were my boat. Not to say that my ways are right.
Question 1: 6061 has rounded corners and is generally used for structural applications where strength is important.
6063 has sharp corners and is generally used where surface finish is more important than strength. Brine has an exceptional build where he uses a lot of 6061 angle for deck supports, but even he admits that this was probably overkill. I think 6063 would have been plenty strong and easier to work with.
Here is his build link for some ideas: https://www.tinboats.net/forum/viewtopic.php?f=21&t=6551
Here is the link to an online metal supply store. I'm not suggesting you buy from them, as it would be way cheaper to buy your aluminum from a local retailer. There is, however, a ton of useful knowledge contained on this site so you can educate yourself on what to buy. https://www.google.com/url?sa=t&rct=j&q=aluminum%20plate&source=web&cd=1&cad=rja&sqi=2&ved=0CEkQFjAA&url=https%3A%2F%2Fwww.onlinemetals.com%2Fmerchant.cfm%3Fid%3D239%26step%3D2&ei=_lFjUcGBPYqs8ASd2IHoBg&usg=AFQjCNEsuuPiOG-1N7xFz4PynKooDKEHPA
Question 2: I would only weld in my flooring if I had access to my own equipment, and possessed the skill to weld aluminum properly. Paying someone else to weld up your boat will add up real quick. Also, if you weld something slightly off, it's a pain to cut and grind it off. Riveting is very popular because it can be made strong, done fairly quickly and doesn't require a ton of skill to master. If you make a mistake with the rivet gun, you can drill out the rivets and start over. Just like with anything else...measure twice, cut once. I would only use screws sparingly, and in places I access frequently. If you screw something together under the deck, who's to say that your screws aren't backing out on you in that heavy chop? If it is an area that you access often, you will be able to identify a loose, or backed out screw and tighten it. Make sure to use good quality SS hardware if you screw anything together. You'll thank yourself later.
Question 3: Check out Steelflex by Fasco. It is one of the most popular paints/epoxies on the market for painting an aluminum hull. Whatever paint you decide to go with remember, 90% of a quality finish lies in the prep work. Only 10% actually involves painting. Here is a link to another similar thread on TinBoats.
https://www.google.com/url?sa=t&rct=j&q=steelflex&source=web&cd=1&ved=0CC8QFjAA&url=https%3A%2F%2Fwww.tinboats.net%2Fforum%2Fviewtopic.php%3Ff%3D3%26t%3D8804&ei=9fNdUbbfDo7M9gTW8IDoDw&usg=AFQjCNF_jbJ-43-6fhwt13ludenMObzKRA&bvm=bv.44770516,d.eWU
    230.1 KB
    62.3 KB
I would agree with everything in the above post except buying aluminum local being cheaper. It may be depending where your at but onlinemetals even including shipping was way cheaper than buying from local suppliers for me. Local supplier wanted over $3 per foot. Onlinemetals price is less than $1 per foot plus shipping. I used roughly 75 feet in my build. You do the math.
Good point, bass blaster. Buying metal is no different than anything else....shop around for the lowest price.
