Motors
Prop problem?
<blockquote data-quote="Boat2fast" data-source="post: 343091" data-attributes="member: 13358"><p>Your in the ballpark now! The dealer sounds like a good one to work with. </p><p></p><p>Listen for the rev limiter to cut in. If you don't hear it you are probably OK. If it is cutting in at top speed, go to a 17pitch.</p><p></p><p>Really, the best thing is to put a tach on it until you get to the boat dialed right in. After that it's not needed much.</p><p></p><p>Taking out the boat and trying new props is an excellent way to spend time.</p><p></p><p></p><p>*************</p></blockquote><p></p>
[QUOTE="Boat2fast, post: 343091, member: 13358"] Your in the ballpark now! The dealer sounds like a good one to work with. Listen for the rev limiter to cut in. If you don't hear it you are probably OK. If it is cutting in at top speed, go to a 17pitch. Really, the best thing is to put a tach on it until you get to the boat dialed right in. After that it's not needed much. Taking out the boat and trying new props is an excellent way to spend time. ************* [/QUOTE]
Insert quotes…
Motors
Prop problem?
